During heavy acceleration sometimes the clutch petal will stay down on the floor during a shift. I noticed in a recent post that this had happened on startup of a new engine but I believe this is a different situation.
 The clutch is an aftermarket diaphrgm unit and seems to have plenty of hook up (does not slip). My spring down on the throwout fork seems a little weak and probably is not a stock piece. Does anyone have a spec for the clutch return spring? Size? Picture?
 I also noticed the rear transmission mount needs to be replaced. The rubber has separated from the steel housing above. Does Chrysler still make this part? I dont want a poly unit due to the excess vibration transfer.
Thanks
Jon
		 by Jon » 28 Aug 2006 19:06
 Only wanted to keep the throwout bearing off the pressure plate when the clutch was not in use. The idea was to eliminate as much petal resistance as possible.
 We will see what arrives next week.
