Petals to the metal
During heavy acceleration sometimes the clutch petal will stay down on the floor during a shift. I noticed in a recent post that this had happened on startup of a new engine but I believe this is a different situation.
The clutch is an aftermarket diaphrgm unit and seems to have plenty of hook up (does not slip). My spring down on the throwout fork seems a little weak and probably is not a stock piece. Does anyone have a spec for the clutch return spring? Size? Picture?
I also noticed the rear transmission mount needs to be replaced. The rubber has separated from the steel housing above. Does Chrysler still make this part? I dont want a poly unit due to the excess vibration transfer.
Jon
Jon
