I was working all day Saturday and slept in a bit the next day so it was 11am Sunday before I got started again.
First job was to stop the overdrive from hitting up against the floor.
Fist step was to grind a little off the case so that I would have to hammer the floor less.
I had already made a start on this last week. The area that needs the most work is outlined. I bit of hard work with the hammer was all it took.
Having a digital camera helped a LOT! No way could I get my eye into this position. The camera does reach up there though and I was able to view the images as I worked.
The next shot shows the unit in it's final position. It seems to have plenty of room at this height.
In the forground you can see the driveshaft safety loop. This was always a bit too far to the rear. Looks like it will be exactly in the right place now.
To get that much room I had to drop the back of the trans a lot. I now had to make the crossmember and trans mount hold the trans at this height.
First I drilled new holes to drop the mount.
Then I had to cut a piece out of the crossmember.
This is how it looks in the car.
The exhaust looks like I made it with the overdrive in mind all along. Bear in mind that the exhaust is hanging down a couple of inches at the moment because it is disconnected from the collectors.
