This stuff looks good, some great ideas and well executed pieces, check it....
http://uscartool.com/
Adrian Worman wrote:My original plan with the Baccaruda was to weld stiffening plates to the highest part of the bulkhead and run tubes from there across the tops of the shock towers and dropping down to the chassis rail, connected at the shock towers with a fabricated steel top hat and a bolted on brace joining the towers together.
I'd like to be able to run the bracing from the bulkhead to the chassis rails from the outer side of the inner fender, if only because the little A body has an already tight engine bay.
I still can't see the benefit of fitting a lower rad brace to stiffen the two frame rails, surely the K member is doing that? It is it just for the benefit of the strut rods?
