I've got the drip rail trim installed on both sides but I'm having trouble with the weatherstripping channel that goes on next.
Is there supposed to be a small notch in the top of the quarter panel at the back of the 1/4 windows?  The stainless lip of the weatherstripping channel hits the quarter panel before it's out far enough to line up with the bottom screw hole.  Also, the notch in the drip rail stainless is still visable...the weatherstripping channel doesn't cover it up.
It looks like there should be a notch in the top of the quarter panel so that the channel can go out farther.  Can someone take a picture or two of the back of the 1/4 glass.....right where the drip rail trim meets the top of the quarter panel?
If there is supposed to be a notch in the 1/4, what would be the easiest fix...cutting a notch out of the weatherstripping channel instead of trying to mess with the 1/4?  Thanks
		 by burdar » 31 May 2011 13:12
 I'll take a pic
 I'll take a pic
