				side glass stainless
31 May 2011 13:12by burdar
				I've got the drip rail trim installed on both sides but I'm having trouble with the weatherstripping channel that goes on next.
Is there supposed to be a small notch in the top of the quarter panel at the back of the 1/4 windows?  The stainless lip of the weatherstripping channel hits the quarter panel before it's out far enough to line up with the bottom screw hole.  Also, the notch in the drip rail stainless is still visable...the weatherstripping channel doesn't cover it up.
It looks like there should be a notch in the top of the quarter panel so that the channel can go out farther.  Can someone take a picture or two of the back of the 1/4 glass.....right where the drip rail trim meets the top of the quarter panel?
If there is supposed to be a notch in the 1/4, what would be the easiest fix...cutting a notch out of the weatherstripping channel instead of trying to mess with the 1/4?  Thanks
				Re: side glass stainless
31 May 2011 20:26by Eddie
				I can get you some pics of my 70 or 72 Burdar if that would help?  If you could further explain what pic you need. I dont understand what part(s) you are describing.
31 May 2011 20:44by Adrian Worman
				I'm with you Eddie, I were'nt too sure either mate, been staring at my 72 and can't quite figure it
31 May 2011 21:07by burdar
				I can take a picture tonight....
The channel that screws on right after the drip rail trim....the piece that holds the roof rail weatherstripping.  I can install all of the screw from the front of the car all the way to the back except the last one or two rear screws.  The small stainless lip of that piece hits the inside of the quarter panel right where the roof meets the quarter...in at the 1/4 glass.  I need to pull that chanel out farther in order to get the last one or two screws installed.  Also, that piece also needs to be pulled out farther to cover the notch in the drip rail stainless.
I'll take a picture of what I have and post it in an hour or two.  Once that piece is installed I can install the weatherstripping and the side glass.
31 May 2011 21:22by Adrian Worman
				Gotcha
 I'll take a pic
31 May 2011 21:35by Adrian Worman
				This right
31 May 2011 22:26by burdar
				Yep, that's it...
There is supposed to be a notch out of the top of the quarter right there that mine doesn't have.  It looks like that channel goes down into the 1/4 window opening farther on mine too.  It could just be the angle I guess.  Thanks for that picture!!!
Sooooooooooo...now what?
31 May 2011 22:32by burdar
				Adrian...are your quarters origonal or have they been replaced.  I finally got the drivers side channel on but it was a PITA.  I looked closer at the quarter panel and it does have and indentation in that spot but it's not nearly as pronounced as the one in the pic.
I was able to twist the channel as I was tightening it down and it almost covers the drip rail notch.  It basically looks like Adrians pic now.  I really appreciate those pics.
01 Jun 2011 8:02by Adrian Worman
				My entire shell is original, they do look more pronounced tho, build quality issues
01 Jun 2011 13:50by burdar
				Can you take one more picture for me Adrian?
There is a small clip that holds the door glass against the weatherstripping.  The clip is located right at the top of the A-pillar.  Can I get a picture of how the roof rail weatherstripping and that clip share the same space?
01 Jun 2011 14:08by Adrian Worman
				Do it when I get home mate, be a pleasure
01 Jun 2011 19:59by Adrian Worman
				Adrian Worman wrote:Do it when I get home mate, be a pleasure
There is no clip
 ..............I'm looking at the top of the front screen pillar yes??????
01 Jun 2011 20:21by burdar
				The clip should be right at the bend where the A-pillar meets the roof.  The clip is rubber dipped I think and holds the door glass tight against the weatherstripping.  Somehow, the weatherstripping need to go in that channel right where that clip is.
01 Jun 2011 21:10by Adrian Worman
				Nope, mine has nothing there, just the weatherstripping stainless moulding. If this clip holds the door glass against the weatherstrip, how does the door close with the glass in the up or closed position?
I can't take a good pic cos the garage lights wash out the camera, but I can have a go in the daylight at the weekend if you want to wait?
02 Jun 2011 20:56by burdar
				Well, I finally was able to get back on here.  The wife and I spent the night in the hospital with our 2 year old.  Anyway...here is a picture of the clip.  It is pretty springy.  I dipped it in Plast-Dip...I'm pretty sure that's how it was origonally finished.  The origonal coating peeled right off in one piece.  It was hard like paint but I think it used to be rubbery.
I can see a rust stain from this clip on the origonal weatherstripping but didn't know how to accually get the new stuff up in there.  I'll figure it out.
02 Jun 2011 20:58by Adrian Worman
				In the garage tonight working on my trackday bike and managed to snap these while I was at it, any good
02 Jun 2011 21:03by burdar
				Thanks, I'm going to go out and work on it right now.  Somehow, that clip and the weatherstripping need to occupy the same space....
I wonder if your car is missing that clip or if they didn't use it in all years?
02 Jun 2011 21:34by Adrian Worman
				I don't remember seeing it when I pulled the stainless trim off but that was 20 years ago
03 Jun 2011 2:44by burdar
				I got the roof rail weatherstripping on.  I just kind of tucked it in behind those clips.  The origonal weatherstripping still snapped right into place in the C channel.  The repro ones didn't fit well at all.  I had to use some 3M adhesive to hold it in place.
I also installed the 1/4 windows.  They aren't in very good shape but I don't have the money for new glass.  It's too bad because the rest of the car is going to look really good I think.  The drivers side is the worst.  Maybe I can find a decent used one for that side?
03 Jun 2011 15:31by Adrian Worman
				Maybe you can polish the glass, there is a link on here somewhere to explain how to use a polishing compound and a mop to get the glass clear again, I'm sure of it
03 Jun 2011 16:25by burdar
				The glass is clear.  That's not the problem.  There are scratches and chips you can feel with your fingure nail.  Polishing won't take those out.
