Hey guys,
After closer inspection of my floor pans, I noticed there was a lot more rust hidden under the undercoating. I'm afraid my car is going to need much of the floor replaced. Since the trans tunnel was previously hacked up, I'm considering a full floor pan. However, before undertaking this task, I'd like to know from any of the members that have performed this, what is involved.
My main concern is how and to what extent the car needs to be supported as the old pan is cut out and the new one is installed.
1) Since my car is a hardtop, what is the best way to install the pan? The pan I was considering is the full front floor and is shown at this link
http://cgi.ebay.com/ebaymotors/1970-Cuda-Barracuda-Challenger-Front-Full-Floor-Pan-70-_W0QQcmdZViewItemQQhashZitem4ceda2305bQQitemZ330404343899QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
It doesn't look like it will simply slip through the window area.
2) I plan on putting the car on a rotisserie for other work. However, since the floor ties into the frame, I don't think the floor can be removed on a rotisserie without causing excessive distortion. How have others supported the car while removing/installing the pan?
3)How much modification of the pan is typically required?
Thanks,
Chris
