 by Joel Bennett (Joel) » 03 May 2003 2:41
			So you welded in one inch pieces, one at a time, correct? You painted the surface to which to the glass sits upon, did you say? Are you using the cement-type windshield sealing method or the non-cement method? I'm wondering, if you used cement to secure your window, wouldn't the cement eventually eat through the paint where the window rests? I know my front window is sealed with cement, but I'm not sure about the back window though. Which do you prefer, cement or non-cement type sealer?
