Standard to R/T Hood hingle bolts question
Postby cv70chall » 18 Aug 2008 18:04
I'm finally ableto replace the standard hood on my 1970 with a Rallye hood and was told the hinges and fit would be fine, but that I might need larger hinge bolts.
Any information on this and where I might acquire a set of these bolts?
Thanks-
We're getting verrrry close.
cv70chall
Postby dave-r » 19 Aug 2008 8:09
Not sure why you would need larger hinge bolts? :?
Re: Hinge Bolts
Postby cv70chall » 19 Aug 2008 12:51
I was told by the nice fellas at AMD and Goodmark that in some case, the hinge bolts need to be larger.
????? :s006:
cv70chall
Postby dave-r » 19 Aug 2008 13:25
Is this Rallye hood a new reproduction? If so they must be hinting at a flaw in their reproduction.
Postby christer » 19 Aug 2008 15:10
From the YearOne catalog:
H774 Reproduction R/T hood: Correct for 1971-74 models only, but will fit 1970 models if larger hinge bolts are used.
I am quite sure that it just is regular UNC bolts. They shoud be very easy to get hold of.
christer
Ghost 48
Postby dave-r » 19 Aug 2008 20:57
Hang on. Do they actually mean LARGER bolts or LONGER bolts?
They go into captive nuts so I was thinking that larger bolts would be tricky? :roll:
Postby Jon » 19 Aug 2008 22:30
Are you trying to be factory correct with the bolt appearance also?
Jon
Postby Alaskan_TA » 20 Aug 2008 1:07
1970 hoods use a smaller diameter bolt than the 1971 & newer hoods.
Length is not the issue.
Alaskan_TA
Postby Jon » 20 Aug 2008 2:37
Interesting subject. My 70 hood bolt is 1/2" hex head with 5/16" coarse thread and an integral washer. The later models would be 3/8"??
I also heard the construction of the hood is a bit different due to newer crash safety regulations.
Jon
Postby dave-r » 20 Aug 2008 7:49
Ah. So if you need to use the larger bolts how do you get around the captive nut problem? :?
It would have been a lot easier if they had made the bolt holes the smaller size. That way they could be drilled out for use on a later model. :roll:
