Flippin' Gas Cap!
27 Apr 2008 23:31
by mopartner
I purchased a flip top gas cap and trim ring for my '70 Challenger from Year One. I have verified that I did receive their correct cap for a '70; however, I'm not sure it is going to fit. The screw pattern is slightly off, but that's not the problem. Just holding it against the body, it appears that the depth of the cap mounts will be an issue. Even allowing for the screw heads, I think the cap and ring will not fit flush against the body - maybe 1/8" or more. In other words, it looks like the indention of the body is too shallow for the unit. I know the cap itself stands out from the body, but the mounts seem too long.
I hate to break out the old screws (which are painted over) if it is not going to work. What do you think?
28 Apr 2008 0:19
by Alaskan_TA
They did not fit "flush". They do stick out a bit on original quarters.
28 Apr 2008 0:58
by Moparman1972
Are you talking about the lower ring not fitting flush? (The one that has the screws) As alaskan TA said, the gas cap will stick out a bit, and you will be able to see the lower ring, looking dead on from the side.
28 Apr 2008 1:26
by 72challengerorange
Will it stick out more than this?
I have heard that replacement quarters have an issue. I'm not sure if you have them though.
Tom
By
tdavist
Flippin Gas Cap
28 Apr 2008 2:03
by mopartner
I know the flip lid will stick out with some of the black mounting area showing. The problem is the trim ring will not fit flush. Year One said to put some caulk around it. Can't see that being right.
28 Apr 2008 2:39
Is it just loose? You can bend the tabs down so that it fits tight.(trim)
Tom
28 Apr 2008 2:53
by Alaskan_TA
OK, that helps.
Once you mount the ring & cap together & torque the screws down it self-adjusts. (compresses to meet the body panel)
Re: Flip Top
30 May 2008 16:24
by cv70chall
So I am correct in reading that you will have to screw into the quarter panel to mount this?
I have a 1970 that came with the standard screw off cap and I am replacing it with the flip-top.
I want to be sure!
30 May 2008 18:33
You use the existing screws that are holding the filler tube to the inside of the quarter panel.
