Jimiboy wrote:Are you driving with a overdrive transmission johannes, or is this something you can use withouth that?
This clever little device is expected to down-shift the Overdrive automatically.
Ex. You drive in 2'nd, and MANUALLY press a button to have the OD upshift,.... so you drive in 2'nd+OD.
You then use the slapstick to get you to 3'rd,.....and this is when the magic is expected to occur,...as the trans upshifts,...the AutoShiftSequencer gets input RPM and Gear-position....and downshifts the OD,.....in the same instant as the tranny upshifts.
...it is supposed to reduce wear on the tranny as well...Hmm...
If it works as expected,...I will get a 6 speed from my 727 + OD.
My engine bay is pretty packed,....and the little box is FAR from water tigth....so that is not a good place to put it....
..Dave,...I spoke to the GV representative,..and he assured me they have gotten rid of all problems.....I'll let you know when the snow is gone..
