Convertible Quarter Stainless Trim
Postby bdola » 04 Mar 2008 16:36
What is the best way to remove the stainless trim on a Challenger convertible rear quarters and the windshield post frame.
Brian :roll:
bdola
Postby jh27n0b » 06 Mar 2008 11:51
There is a special tool for undoing the clips that hold the windshield molding on. It slides under the molding and releases the clip from indside the molding. The molding on the quarter panels requires a Phillips head screw driver. The well liner has to be removed and then you need to undo the top where it attaches to the tack strip at the rear. You then need to remove the tack strip. With the tack strip out of the way, from under the top edge you should feel Phillips head screws that hold the molding on.
I am going off my memory of when I did all of this 4 years ago so that will be my disclaimer if my info is faulty. :lol:
Bob
jh27n0b
