I'm glad I saved the adheasive strips. I can tell exactly how they went on the car by the impression the drip rail trim left on them. They weren't installed very carefully that's for sure. It looks like they were pretty crooked. Here are some pics...
Here is one of the drip rail pieces. You can see some of the gasket still stuck to the end. It the background is one of the stripes that goes on the car before the drip rail trim.
Foam strip still attached to the window weatherstripping channel.
A pic comparing the two strips. The one that goes on the car first is a lot wider than the other one.
How far down the vinyl was applied to my car. I'm going to trim about 3/4" off.
Finally, where the first foam strip is installed. Accually, it should be installed up higher...the bottom of the strip should be right where the top of the strip is in this pic.
This is on a 73 so maybe they didn't do it this way in earlier years. I have no idea. This just how mine was done. This was an origonal owner car with origonal top when removed.
