Thedeputy wrote:The striker consists of a bolt and a bushing. The bushing slides over the bolt and inside the metal bushing is a rubber bushing. Maybe that rubber bushing is worn out?
Antoon
airfuelEddie wrote:Christer, I was looking for some reference places for parts on your striker no luck. I did think though, wonder if B-Body or other MoPar's had a similar setup? This way the part may be easy to locate if we knew they cross referenced to more readily available parts. I have a set of strikers for trucks but they are one piece and the bushing became integrated with the shaft,(one piece). Just a thought
airfuelEddie wrote:Christer, I know where a pair of 70-74 N.O.S. Door Strikers can be had but it's pricey 65.00 a pair! www.chetsautoparts.com at least they are available.
Good to know that they exists.
dave-r wrote:Stuff the bush with silicon sealer and wait for it to go solid. Then put it back on the car. Job done.
At least that is what I would do.
I use to feel bad when I think of it. I wonder what has happened to the car?
dave-r wrote:1970 Challenger doors never went "click" even when new. One of the major faults on all new challengers was the loud rattle when you slam the door even gently.
He must have done a lot more than adjust the door striker to get a good result.
Jimiboy wrote:dave-r wrote:1970 Challenger doors never went "click" even when new. One of the major faults on all new challengers was the loud rattle when you slam the door even gently.
Then you guys should be impressed also if you heard.. it's more a "thock" then a "klick"
(Mostly a joke, but on the other hand, why not?
I always, always and always am very accurate were i keep my hood pins as i have the hood off... But this time there were som sort off other circumstance that maked my brain flop!
(This will hopefully never ever happen again!)
Lucky nobody got hurt or was in the surrounding area! (This is really stupid to write in a public board, but i can take it like a example of warning!)
airfuelEddie wrote:Man,you were lucky, it could have been much much worse my friend!
..soon or later, i guess! Even do i thought i could call my selfe careful!
