When I removed my SE rear window glass , there was a rubber gasket and window sealer/glue to hold the window in. I'm now ready to re-install the window. I can't imagine there is a replacement rubber gasket. If there is, where can I get one?
If not, I assume the window is just glued in (like the windshield). If so, should the glue bead be thicker to compensate? If so, how high should the bead be?
Thanks!
