I'm in need of a second opinion or just some striaght up advice.
The car I'm restoring is rust free. Unfortunately something was set on teh roof and slightly depress the are so it is about an eighth of an inch down in the center. I can push it up from underside, but obviously the metal has been stretched a bit cause it just pops back.
Is there a way of poping this back up, with heat or should I use filler. The area pushed down would probably be a foot around once filler is applied and blocked down. Surely, this is common among many resto projects. How do others resolve this silly, yet complicated issue.
I do have a donor car which has a perfect roof, but turning that way seems like too much work.
I'd appreciate any help. Not sure who I should ask????
THanks guys.
Brant
