 by Rizrtse » 04 Nov 2001 21:58
			Frank, I chose to not install the lower clips that go through the body if I ever choose to remove it I didnt want the holes (we filled them in). The panel, attached from the ends with the normal quarter clips holds it pretty well. When the lock cylinder is put through from the outside of the panel, it holds the lower half nice and snud against the body. Problem is, the u-clamp doesnt grab the cylinder at the same section inside the trunk side like it used to because the cylinder is drawn out a bit. Help
