Mirror Threaded Plug
24 Apr 2005 13:00
by roadrunner
There appears to be a threaded plug in the door panel that the mirror BASE screw threads into. Any thoughts on where I can get these?? I lost 2 during mirror removal. They (plugs) are factory and must be some sort of expanding plug.
24 Apr 2005 14:23
They are an insert that is installed with a gun that looks like a rivet gun. I think this has been discussed on here before. Can't remember what was said on the subject though...
25 Apr 2005 11:09
by roadrunner
Thanks Dave. I will continue to poke around and see what I can locate. It's not real easy to put your hand in the top of the door panel to put a nut on an attachment screw.
04 May 2005 4:38
by Charlie Backes
They are called Riv-nuts and I found a local hardware store who sells the gun to put them in. The goods tools are quite expensive. I think Year One sells the steel riv-nuts but not the tool to put them in. I found some aluminum riv-nuts and will try them out, heck they work well on aircraft!
Charlie
11 May 2005 11:43
by roadrunner
Keep me posted. What was the name of the hardware store? I did manage to have my son who has small hands snake his way up through the door panel and put a nut on a bolt to hold it (mirror) in place. However, I do need to remove the mirror again to tighten the bolt that attaches the mirror to the suport that attaches to the door. So if I can get one of these nuts to work it would sure be easier.
11 May 2005 16:28
13 May 2005 11:39
by roadrunner
Great job!!! Since I am not good at EBAY I will have my son bid on it. Thanks again!!!
