Ok on my 1970 I've tried to pull the tabs for the front window trim but no luck. I've got about 7 different types of trim tools, which one should work the best and how?
thanks,
If you're referring to the clips that the trim snaps into, in 1970 these are held on by a phillips head screw. You'll have to remove the windshield in order to replace the clips.
I think he was asking about removing the trim from the clips and not the clips from the car???
If so I usually use a very thin screwdriver to press on the inside of the clip. It helps if you know exactly what the clip looks like before you start.
