 by Roger Bettoni (Roger) » 29 Apr 2003 22:58
			Joel - I did Jeff's fix-it suggestion the other day and had good results. There are four bolts, so you'll need four washers (mine only required one washer per bolt to raise the door sufficiently) for the bottom hinge. I also had to re-align the post that the door latches on, as this was out a bit too. I found that using two jacks (one at door hinge end and one at other end) helped me with raising the door to the required height. Loosen the top bolts a little then remove all bolts from the bottom, put a little grease on the washers to help hold them in place as you put bolts back in. Easiest if you don't remove door entirely.
