by frank » 28 May 2001 3:01
boy marcus what have you gotten yourself into? i am assuming you are starting at the beginning. *grin* i started at the bottom and went up, did the front end and w/out the fenders on is WAY easier, then the rear,the fuel tank(do check this out and change the tank filter) then the undercoat, the lines (fuel/brake)then did the inside i used por 15 on everything as challengers are rustprone then i put the fenders on this is a major showingpoint and really takes patience and time to get right marking on the body of the car w/a pen before removal can make this easier if you aren't painting over it. i then put all the headlight hardware in and then the grill. then the bezels,and i think i put the lower valance then the bumper, on there are rubber bumper guards that fit into the edges of the bumper dont forget to install these before you put the bumper on, i am sure i forgot some things so refresh my memory when you get done.
