 by Hans (72challenger) » 14 Oct 2002 10:52
			I'm doing the same thing, so here are some things I will change. There is a 'device' near the battery tray which connects a couple of wires (from there you could start the car someway) and there's also something on the driverside of the radiatorsupport with multiple wires. I will place these two things under the battery tray, out of sight. The orange ignition box will stay in his place but the coil will be moved under the ignition box and the voltage regulator on the left side of the orange box. For the rest I will reroute the wires in the way I like it and put everything in some flexible black plastic hose.
This way everything will look nice sharp and clean, but it's quite a bit of work. But hey, what you want to do else in wintertime? Sitting in front of the fireplace...not!
And I will do more, but I forgot.
