BTW, congrats, nice car for sure man.
fal308 wrote:You might want to slap on a new see-thru fuel filter also, so you can gauge how much crud is in the fuel tank. Or better yet, run a short length of fuel line from the fuel pump to a gas can so you are running fresh fuel. Thus bypassing the fuel tank altogether. Also, only if you're comfortable doing it, pour a small amount of gasoline down the carb throat to start it as the fuel pump and lines will most likely be dry.
Have a fire extinguisher nearby as you don't know the cause of the fire on the driver's front, though I suspect an electrical short
Does it have a tachometer outside on the hood? 160 MPH speedo? Console shifter? If it's 4-speed your sitting on a lot of potential cash! We have a member here called 'Daytona' who owns a Judge!
So it's an automatic transmission equipped car Wayne? BTW, does it have the 'machine turned' dash? I always thought those were the best looking dashes ever made.RedRaven wrote:airfuelEddie wrote:Nice ride Wayne!
and she was a nun and could fly too!airfuelEddie wrote:Cool Wayne. Yes, they have the respect any large cubic inch plant like that has and they made em when Ford and Chrysler had gotten out of 2-door big block cars. Plus Sally Field looked pretty good with a pair of shorts on in the passenger seat.(30 years ago)!
