				Overdrive 46RE into a chalenger
02 Mar 2008 15:25
				by jmemoli
				Hi ,
I am new to the board -
Is there any posts or does anyone have information on the "how to" "pros" and "cons " of putting a newer 46re overdrive transmission into an E body ?
02 Mar 2008 16:40
				Wouldnt the transmission tunnel be pretty big in the E-body with that transmission in there? That tranny is a truck based electronic torque convertor controlled lockup unit and although is based on the 727 is much larger? It's PCM controlled as well.
02 Mar 2008 19:34
				Fit a Gear Vendors unit. Job done.
I have a massive thread on here about how I did mine.
04 Mar 2008 1:54
				by jmemoli
				Thanks guys
04 Mar 2008 14:22
				jmemoli wrote:Thanks guys
U.S. car&tool makes a 'conversion' rear motor mount and as I have since discovered, the transmission tunnel clears.
04 Mar 2008 15:41
				I assume it is small block bolt pattern?
04 Mar 2008 22:31
				dave-r wrote:I assume it is small block bolt pattern?
I saw it another site Dave. To be honest I dont know. I would however assume it is unless an special adaptor plate that fit between the back of the block and bellhousing would have to be fabricated for a B/RB block
