is there a purpose f or the srewed on hatches under the rear seats
i want to weld them closed
just one more place to let crap and moisture in
hey i have that screw on plug too. when i was searching for my build sheet under the rear seat i also noticed that metal plug with screw. i would just take it appart,clean it real well and leave it as is then spray a touch of krown t40 on it to protect it from rust for good.botari123 wrote:here is a pic
two rubber plugs over frame rail
1 screw on plug in middle of floor under seat
dave i think that metal plug is stock to the car,mine also has it and the floor has a little notch cut out so that metal plug slides into place before you screw it back down.dave-r wrote:It is hard to get my bearings with that photo but on my 1970 car I have a third hole (bigger than the other two) with a plastic plug in it at about that position.
The screw on cap that you have looks exactly like the ones that should be over the rear shock absorbers for access to the top shock mount.
Maybe someone got them mixed up at some point in its life?
