by dave-r » 17 Aug 2007 7:54
			Jack is right. Even though the front might look level, if one front torsion bar is tighter than the other it effects the height of the opposite side rear suspension.
It is a bit like getting a 4 legged stool to sit on the floor right.
My own car was too high on the left rear. I wound down the front right torsion bar a little and it straightened out without effecing the front ride height.
It is a case of measuring, adjusting, bouncing the suspension and measuring again - at all 4 corners - until it is right. Or as right as it will go.
I was measuring from the top of each wheel rim to the center of each wheel arch to get it right.
