Advice on buying a 1971 Challenger
I have the opportunity of buying a 1971 Dodge Challenger R/T. It's almost compleat but needs a full interior and exterior restoration. The car has almost no rust, all the panels are good. Just needs a paint job. The interior is compleat, but all panels are in bad shape, can they be restored or must be replaced? The upholstery is not original, must be redonde, also the ceiling and carpet. The instrument panel is compleat, front console needs work. Some exterior chromes are missing. The front grill is broken.
However, the engine is not the original, it's a 383 from a 1963 Chrysler Newport. There's a posibility of getting a 440 engine from a 1967-68 Chrysler Imperial.
I have several questions: A Challenger without the original engine (the drivetrain is also not the original) is still worth something? How much? Is the Newport engine similar to the one used in the Challenger? Is the 440 engine from the Imperial the same as the one used in the Challenger? t's not the 6-pak, it has only 2 carbs. Perhaps it can be converted?
They are asking 4.5k for the car with the 383 or the 440 engine, it's my choice. I live in Peru, outside the US and it's not easy to get a Challenger. Please advice!
Also there will be a 1970 Challenger available, fully restored and with matching numbers for around 13k. But I guess I will have to restore it again. I've seen the work of those guys and it is very bad. Which one is a better buy?
thanks,
Javier
thanks,
Javier
