I have found a new home in PA. It is over 100 years old so getting the heat on & many other repairs taken care of before the cold weather hit was a priority for me. There is still a lot to do as well!
The 'Found' item section is back on line with 88 new items added from the late 1960s into the early 1970s, most of them are for 1970 LA built cars.
New Registration forms have been loaded up with my new mailing address on them.
Services are available again.
Special thanks to Rosemarie Michael, Cody & Jenesa Reich, Sean & Sharon Harbour, Peter & Sheri DeVos, the entire Drake Family, Jackie O'Brien, Jeff Bangert, Crazy Jimmy & Big Mike for their help & support with my move. I could not have done it without you guys!
Thanks go out to Mike & Doug also for adding new site content while I was out of the loop!
Thanks to Jeff Bangert (again!) for handing over a whole stack of 1970 records for LA built cars. Thanks to the folks that handed off some other original items to me along the way also!
Check for your VIN in the "found" section at http://www.hamtramck-historical.com to see if any of the newly posted records match your car.
Barry Washington
