				5 blade 4 bolt mopar original fan??? anyone
24 Aug 2010 17:35by 73challengerguy
				has to come off a clutch fan set up.....cant be a 4 bolt non clutch...pattern is different.....prefer a 5 blade...what do you have?....fan cant span much more than 18 inch across....thank you
25 Aug 2010 13:56by Eddie
				Since I'm not getting that Duster, you can still have this one Jeff. It's a 7 blade Chrysler Fan for an A-Body with the Part# and the Pentagram on it.
25 Aug 2010 14:10by 73challengerguy
				THANKS eddie....how wide is it again? tip to tip of the blades...thats the biggest problem is finding one thats not too wide and will rotate above my  radiator...since i dont have a shroud...the ones i have found are so wide u couldnt even run a schoud, it would interfer......let me know....and do u think having the heavier,fan with the 7 blades, would be hard on the clutch bearing spinnin with the extrea weight of that fan??  anyone input here??
25 Aug 2010 14:39by Eddie
				73challengerguy wrote:THANKS eddie....how wide is it again? tip to tip of the blades...thats the biggest problem is finding one thats not too wide and will rotate above my  radiator...since i dont have a shroud...the ones i have found are so wide u couldnt even run a schoud, it would interfer......let me know....and do u think having the heavier,fan with the 7 blades, would be hard on the clutch bearing spinnin with the extrea weight of that fan??  anyone input here??
 It's exactly 19.5 inches across the centerline blade tip to blade tip. As far as the extra weight, I dont think it will be an issue, the belt tension dictates the force upon the bearing plus it's the water pump seal that goes bad, not usually the actual bearing.
25 Aug 2010 14:46by 73challengerguy
				sorry man.....too wide...thats like the one i have now....over 19 inches.....wont work......thanks anyway
25 Aug 2010 14:51by Eddie
				No problemo man
25 Aug 2010 14:56by 73challengerguy
				i CATN FIGUFOR THE LIFE OF ME WHY THIS IS SUCH AN ISSUE,...THE MOPAR FAN CLUTCH AND FAN DEAL IS A PERFECT FIT, FAN WIZE...BUT I CANNOT BUY THAT FAN ONLY....HAVE TO BUY THE WHOLE DEAL.....AND I CANT FIND THAT 15.75 WIDE FAN ANYWHERE???
