Hi, does anyone want to sell or know where to find a Challenger emblem for the rear tail panel of a 71? I broke it while installing the panel. The numbers on the back are 3570519 94200 , it has 3 pins and a stick on wont work properly because the two panels dont sit flush and i think it would pop off. I tried JB weld and that didnt work either. Thanks.
www.manciniracing.com used to sell them, I think they still do. $41.95, though I'm not sure if it's the one you want. The site doesnt say. You can call them toll free at 1-800-843-2821 or Year One! Found them. www.paddockparts.com $60.95 PAD02743 I would still call to make sure it's the stud mount and not the adhesive mount.
Thanks Eddie, I think they both only have the adhesive backed ones but maybe i'll call on Monday and make sure. The problem is that the panel is two pieces and mine bump out a bit where they join together and i dont think they will stay on.
If for whatever reason you cant get a new one Chris, you might want to fabricate a piece of steel that fits into that "groove" then both pieces can be bonded together. A 'bond' at the small point adjoining the 2 halves wont work, there isnt enough surface area to affect a repair. The emblems themselves are made form zinc and alloy. (Pot metal).
