You should try and use at least 7290 U-Joints,, this is what the factory did on 440 engines,,there is only 1 brand I recommend,,,SPICER!!! Don't use overseas Joints,,I've never seen any that held up,,at all!!!! Make sure they are installed correctly,,you can put the C-clips in the wrong way, it will work for a while then POP!!
