I havn't been on here in quite awhile.  I had computer problems and work has been slow so I've had to go back out into the shop for the winter.  I'm still working on the car though.  I've accually gotten a lot of parts refinished this winter.  I have a batch of fasteners to RPM tonight as a matter of fact.  I've been working on redoing the rear end again but don't want to show pics of it until it's done.  I had the housing power coated but the pitting still remains.  I need to have the pits filled and get the housing repainted before I put it back together.
Here are some pictures of things I've finished so far this winter.  I should be on track to getting the engine installed this spring.
The calipers are reman pieces I bought a long time ago.  The had a little surface rust on them from sitting.  I blew out the pistons, removed all the seals, cleaned off the rust and RPM'd everything.  I also RPM'd the new brake hose ends.
I had previously painted all the suspension parts with POR-15.  With as much trouble as I had sanding off the POR on the driveshaft, I looked for a product that would remove it.(regular paint stripper won't touch it)  I found the POR accually makes a paint stripper that works on the POR-15.  It's called POR-Strip.  Anyone that needs to remove POR-15 needs to get some of that stuff.  It works awsome.  The POR-15 just wrinkles up and flakes off...it doesn't turn into a gooey mess like regular paint.
I stripped the POR off the spindles and caliper brackets and then sand blasted them.  I used the black oxide solution I've been using on the fasteners and brushed it onto the spindles/brackets.  I RPM'd everything separately before assembling.  The finished prodect came out too dark but I'm still pleased with the results.
Everything in this next picture is original except for the tie rods.  I've been using muriatic acid to derust parts and it works great.  EvapoRust is expensive and loses its strength quickly.  The acid cleans the rust off fairly quick.  The only thing you have to do is neutralise the acid once your done.  I've been using baking soda water.  The center link and strut rods were stripped of POR and put in a smaller piece of PVC with the acid.  Once the rust was gone, I filled the PVC with baking soda water and let them sit over night.  The next morning I rinced them off and RPM'd them right away.  The tie rod adjuster sleeves were soaking in acid as well.  I lightly wire wheeled them once the rust was gone before RPMing.(same thing was done to the clamps)
I didn't want to use the acid on the original idler arm.  I checked it over and found that it was still in great shape.  I soaked it in EvapoRust, RPM'd it and sprayed some grease in lower end.  I even saved the original rubber boot.
The last picture is of the LCA's.  I had these sand blasted.  I darkened the torsion bar socket and the cast lower ball joint piece along with the rivet heads.  I rubbed the arm with steel wool, then masked off a dip line.  I sprayed the LCA's with Krylon Battery Protectant.  It's transparent and dries fully like paint.  It doesn't stay tacky like real cosmoline.  I sprayed a matte clear over the battery protectant.  Once the paint was dry, I heated up the entire arm and RPM'd it.  This picture was taken before the RPM was applied but it didn't affect the paint at all.
