Update suspension
PostPosted: 02 Jan 2009 10:51
by Glen Miller
I have a 70 440 I am compleatly stripping and rebuilding and I am wanting to put a tube K frame and rack and pinion steering I am in Australia and trying to find info down here on this is hard. I have looked at Magnum Force who have their Pro Street K Frame, Suspention, Steering and Brakes as a replacement kit for $3500. Has anyone used this product or one similar and have any feedback. Also I am trying to find a Goodmark supplier who will ship to Australia as I require New
Firewall
Cowl
L & R Lower Cowls (A Pillers)
L & R Front Fenders
L & R Door Shells
Any help would be greatly appreciated
Cheers Glen
PostPosted: 02 Jan 2009 12:47
by ianandjess
gday glen welcome to the board where abouts are you
the freight on the parts you need will be a killer if you can afford it youll be best off buying it all at the same time & having it put in a crate & importing it
where did you buy your car
cheers ian
Re: Update suspension
PostPosted: 02 Jan 2009 15:40
by fbernard
Hi Glen.
I did the same kind of research last year as I was building my car for road racing and vintage rallies. The first I saw was Magnum Force Racing's. I didn't like it because (back then) it had no engine mounts (elephant ears were mandatory). And it used the inner fenders for coil-over support. I don't know how you feel about using 1.2mm-thin sheetmetal to dynamically support the 950 kilograms that are resting on the front-end, but 'street-worthy' isn't what comes to my mind.
I ended up using Reilly Motorports' AlterKtion setup for two main reasons :
(1) Up until a short while ago, Bill Reilly's K-member was the only one to have an integral upper shock mount, whereas Magnum Force, CAP Auto, and others use the OEM fenderwell mounting point, which is not meant to absorb the thrust of a coil-over shock.
(2) Of all the guys I asked information from or had prior business with (CAP, Magnum Force), Bill is the friendliest, most helpful, and his setup has a lot of supporters (on moparts and other forums).
Bill has started making torsion-bar versions of his AlterKtion too (with short torsion bars hidden inside the K-member tubing).
Now, there are two other suppliers for K-members that feature complete suspension mounts : XV motorsports (extremely expensive), and Control Freak Suspensions (an AlterKtion knock-off, the firm primarily makes Ford & Chevy suspension parts, they started on mopars this year). I wouldn't recommend either.
Installation is easy, the only real work is to remove the bump stops from the fenderwells and drill 2 holes per side on the framerail.
A friend of mine made a few videos when we installed the K-member in my car, here they are :
http://www.agitatum.fr/video/4hb/index.html
I've used very stiff springs, and I'll go back to lighter springs this winter (550lbs/inch to 450).
Other modifications include Hydroboost brake assist, 13" rotors and 6-piston calipers (Wilwood setup, the K-member uses Mustang II spindles so brake kits are easy to find).
I'm so satisfied with the front-end that I'm installing Bill Reilly's rear 'Streetlynx' setup this winter.
My car handles like a sports car now. The rack steering is good, assistance level is fine (not too assisted).
I do recommend frame connectors and torque boxes, though. I'm installing these this winter too (well, If I can get a hold of Auto Rust Technicians, that is).
Now, I don't know what you plan to do with your car, but great improvements can also be found with the original K-frame, big torsion bars, good shocks, etc. for much less (less assisted than stock steering box from Firm Feel, 1.12" torsionbar, swaybars front and rear, double adjustable front shocks). DrDiff makes adapters that will let you mount a 73+ brake rotor (including the big 11.75" cop-car pieces) to a 1970 spindle.
There's another guy on this forum, from Poland, who also installed an AlterKtion, maybe he'll chime in.
You should definitely head over to Moparts and look around, too. Lots of people there with experience in tubular K-members.
PostPosted: 03 Jan 2009 6:58
by Glen Miller
Hi, Im on the Gold Coast Queensland, I went to the US in 07 and purchased the car along with a Cuda I sold back here. The Challenger was a running driving 440 6Pac 4speed car but I was unhappy with the finish on it and stripped it only to find way more than I expected.
Thanks for the info re the K frame.
Cheers Glen
PostPosted: 03 Jan 2009 11:19
Personally I feel that replacing the K-frame and adding R&P steering are both a waste of time. I doubt very much that my car would handle any better than it does now with it's original type quicker ratio manual steering.
The K-frame does not add a huge amount of weight to the front. Coil springs do not work better than torsion bars.
Challengers are two ton saloon cars. They are not MB sports cars (thank God) or Lotus/Caterham 7s.
If you want to really improve the handling fit a small block, chassis connectors etc.
:p:
