Wow, Dave's right about that lighting making a huge difference! It almost looks like 2 different engines! Yeah, the 2.02 Intake 'X' Head which both of you have is the same head configuration wise as all 2.02 valved 'U', '915' heads of that era with the sole exception of the T/A pushrod relief and the fact that the intake port pushrod pinch is able to be taken out and offset intake rockers used to allow more airflow and a larger intake port on the modified 305 Cube Keith Black Trans Am racing engines Ma MoPar used in 1970. The advantages of the closed combustion chamber are many. One important feature is the fact that it reduces the burn time across the piston because the piston head is usually flat or dished. This helps to reduce the burn time which is measured in milliseconds. This then produces a more efficient burn and produces more power with less timing lead. The older open chambers used a pop-up or dome to reduce the combustion space. This reduces the efficiency by making the flame travel erratic and requires more timing lead to complete the burn or power stroke. This can cause detonation or pre-ignition. It's also easier to build compression with smaller closed chambers than it is with open chambers and domed pistons.(The factory 340 had a positive deck height of .040 I think, which is why Edelbrock makes two different heads for the 340's, one is open and the other closed, the factory piston 'stuck up' into the head .040) You can still make big power with open chambers Jon, and there's really nothing wrong with the design. it's the fact that over time the design has evolved to where the most power can be made with the low grade fuel we have anymore. Fast burn, high velocity&swirl, good balance between both ports flow, small chambers are the current designs. This has primarily benefited both power and emissions. The only advantage of open chambered heads was the fact that they helped low speed intake flow"through" the valve seat area at low lifts better with an open chamber, BUT this advantage is negated as soon as the valve reaches a height of over .100 or so. Of course this was back in the 60's so...Views expressed are my opinion only. The FACT remains that you two have some VERY nice 340's and with tube headers Jon's screams pretty good I bet!!!!!
(I ran a 340 for a few years in the mid 70's,,it never let me down,,, Winter/Summer it didnt matter,, I miss it too)
