got the floor welds all cleaned up
and the XV frame connectors all smoothed in
cant wait to get to the part that counts
botari123 wrote:and the XV frame connectors all smoothed in
christer wrote:botari123 wrote:and the XV frame connectors all smoothed in
they looks fantastic if you ask me. nicely done job too.
botari123 wrote:got the floor welds all cleaned up
botari123 wrote:how do u quote in the wite box?
christer wrote:(If you by accident deletes one "]", then I suggest that you start all over. Just adding this "]" sign back again usually does not work, at leaast not for me. You will probably not get any white box due to some error in the programming.)
jr wrote:christer wrote:(If you by accident deletes one "]", then I suggest that you start all over. Just adding this "]" sign back again usually does not work, at leaast not for me. You will probably not get any white box due to some error in the programming.)
You can add brackets by hand if required which is exactly what I did now when replying to your post. If it's not working you probably have extra space between.
