airfuelEddie wrote:How did it run? You told me it was running a little rich at low speed? Do you have a O2 bung in the collector(s)? Did the cold temp make a difference in the engine's performance? Yes, VERY BRAVE to take it out in those cold slippery conditions! Nice pic, your R/T looks wicked fast!
 (It's also nice to see the beemer n the rear!!)
Ran beautifully on the track. I don't have the WBO2 probe installed at the moment, I took it out a while back and didn't put it back on (I needed everything firmly held for the rally in September, and didn't want loose accessories hanging around). I've been wondering about the cold weather affecting performance. I probably should have changed jets a couple sizes up (cold = denser air), but my spare jets were sitting on the shelf back home when I thought of it. The only mod I could do was to switch the secondary carb spring (I was using the road carb, which was a good thing, I don't think I could have driven home with the double-pumper).
I was a litle wary at first, with the snow and summer tires, but after a few laps, everything was definitely fine.
Went to 150 mph on the straight line, probably could have gone more, but I still like to have at least 200 meters to brake...I know I have to work on that, but not on a cold winter day!
And it was not too shabby in the turns.
While some of the smaller road rockets did pass me (mostly VWs, one Alpine A310 with a well-tuned chassis, that Alpina B10 in the background, one Elise), some much lighter cars (Alpine A110, 1 ton less than the Chally) ended up going through the gravel pit after passing me. I love those tires, I can really feel the limit driving through corners.
All cars were passed again in the straight line.
I only lost control twice (stayed on course once, stayed on the track but stalled the second time). That was at the end of the morning, when the wet track was starting to freeze again.
I did all the track with 4 gear changes. (4th to 3rd at the end of the straight line, 3rd to 2nd before a sharp left turn, back to 3rd right after that, all the rest in 3rd and 4th during the straight line.
I tried using the 5th once (when I was past 6300 RPM in 4th), and it still acelerated a little, but not that much. Better stay in 4th.
I have a heavy vibration in the rear-end when I accelerate at full charge in 4th, though. I guess the rear-end nose angle is not good.
I can't say it ran very well on the way home, with the heavy rain and the big scoop. Soaked air filter, even my oil breather filter was wet, and there was water condensing in my valve cover breathers!
Time for an oil change...
