 by 73challengerguy » 18 Jun 2008 19:08
			thanks guys.....its a 400 low deck with a 440 steel crank....hence a 451 stroker.....10.5 comp......568 lift cam motion roller.....comp promagnum roller valvetrain..eagel h beam rods, diamond pistons.....custom flowed 452 steal heads. (285 flow)......single plane m1 with a 850 quick fuel tech carb,...aluminum water housing, march pulley system,.carter strip fuel mech pump......msd igintion, mech billet dist........didnt dyno it cause i ran out of cash.....lol.....but a non roller setup like this makes 500hp....so im figured over that with the roller factor.......83/4 with 391 sure grip......proffesionally built 727 bolt in sprague, with a custom built dynamic 3500 stahl........
