				gettin ready to fire it up.......after 9 years...lol
13 Jun 2008 14:28by 73challengerguy
				here my baby....getting close.....thanks to all the help from people on this site thats gave me good advice and guidance
14 Jun 2008 10:20by RedRaven
				Wow after nine years..I salute you sir!!
14 Jun 2008 13:41by 73challengerguy
				yeah after nine years of pinching pennies and scraping u dollars....takes alot of cash to put one of these together.......as alot of people know on here
15 Jun 2008 13:33by Jimiboy
				Wow! I like the colour. It is not the most regular... Please post more pic's if possible. Looks nice!
15 Jun 2008 13:39by Jon
				Looks nice, love the color also. That is one dedicated effort you have put together.
15 Jun 2008 14:48by bananaskin
				Looks very nice
18 Jun 2008 16:38by 73challengerguy
				thanks guys......appreciate it.......havent really ran it yet....just breaking it in.......
18 Jun 2008 17:44by drewcrane
				73challengerguy wrote:thanks guys......appreciate it.......havent really ran it yet....just breaking it in.......
you must be a little nervous after 9 years,looks real clean, nice car man,kinda like the 70,s all over again huh?!
				Color
18 Jun 2008 18:11by moparman11
				That is a very nice car, good luck, John
18 Jun 2008 18:37by Eddie
				Man, that is one gorgeous Car!
 Can you give any specs on the engine? I see you run a single plane and big Holley with spacer and milled choke tower, cool billet vacum canister on there too.. Flat tappet cam? Roller, stock or worked heads? It looks brutal!
18 Jun 2008 19:08by 73challengerguy
				thanks guys.....its a 400 low deck with a 440 steel crank....hence a 451 stroker.....10.5 comp......568 lift cam motion roller.....comp promagnum roller valvetrain..eagel h beam rods, diamond pistons.....custom flowed 452 steal heads. (285 flow)......single plane m1 with a 850 quick fuel tech carb,...aluminum water housing, march pulley system,.carter strip fuel mech pump......msd igintion, mech billet dist........didnt dyno it cause i ran out of cash.....lol.....but a non roller setup like this makes 500hp....so im figured over that with the roller factor.......83/4 with 391 sure grip......proffesionally built 727 bolt in sprague, with a custom built dynamic 3500 stahl........
18 Jun 2008 19:20by Eddie
				73challengerguy wrote:thanks guys.....its a 400 low deck with a 440 steel crank....hence a 451 stroker.....10.5 comp......568 lift cam motion roller.....comp promagnum roller valvetrain..eagel h beam rods, diamond pistons.....custom flowed 452 steal heads. (285 flow)......single plane m1 with a 850 quick fuel tech carb,...aluminum water housing, march pulley system,.carter strip fuel mech pump......msd igintion, mech billet dist........didnt dyno it cause i ran out of cash.....lol.....but a non roller setup like this makes 500hp....so im figured over that with the roller factor.......83/4 with 391 sure grip......proffesionally built 727 bolt in sprague, with a custom built dynamic 3500 stahl........
Very Very Nice! I bet it makes 500+ H.P. EASY! I bet it makes well over that mark! I also bet traction is you're biggest or will be you're biggest 'problem!
 Thanks for posting your build! Eddie
18 Jun 2008 20:16by 73challengerguy
				running  super stock springs with pinion snubber, and 11.5 wide nittos rear tires????????
18 Jun 2008 20:25by dave-r
				That is a great combo.
18 Jun 2008 22:00by drewcrane
				yes now you gotta learn how to put the power where the rubber meets the road, if so mid 12, to low 13 secs. should be no problem
18 Jun 2008 22:31by RedRaven
19 Jun 2008 4:51by patrick
				Very Nice, Beautiful car, 73 Challenger Guy!!!
19 Jun 2008 10:05by jr
				What colour is that? Looks bit like Sienna Tan Metallic (KT5) that my '74 was from factory. There's still some original colour left under back seat, other than that it's blue nowadays.
19 Jun 2008 14:50by 73challengerguy
				it better run better than 13 or 12's with that hp.....cripes my v6 grand national ran high13's out of the box.....ill be disapointed if  a 500+ car doesnt run low 12's high 11's
the color i believe is burnt bronze mettalic
19 Jun 2008 15:11by dave-r
				It should run 11s. Probably has more than 500hp too.
19 Jun 2008 15:43by 73challengerguy
				well like i said the guys that puts these together says....the 451 is a 500 hp motor.....then i went roller?...his number is flat tappet.....so i dont know how much i gain goin with the roller....anyone know?....
19 Jun 2008 19:46by Eddie
				At least 50 H.P. especially past 5000 RPM"s cause your roller springs give much better control but the real advantage comes from that huge and wide roller cam intake lobe. It can be ground much more aggressive than any flat tappet. ANY!
19 Jun 2008 21:08by dave-r
				Yep. I was going to say about 25 to 50hp.
10 Jul 2008 10:48by DAYLEY/CHALLENGER
				Hello 73......Looking good............
11 Jul 2008 12:23by ianandjess
				awesome job thats just incredible im extremely jealous right now
cheers  ian
11 Jul 2008 15:21by Eddie
				I cant wait to hear the update once he gets the spark curve the plant needs for max performance. it's gonna take a lot of lead, quick curve to 2800-3000, all in by 2800 or so. 34-38 total. NO vac. advance!
