 Wayne, yours looks sweet man, do as Dave says and it will be much cleaner in there.
 Wayne, yours looks sweet man, do as Dave says and it will be much cleaner in there.  Oh and tighten that wing nut on top of the air cleaner!
RedRaven wrote:This is my engine bay....needs work...
moparman11 wrote:RedRaven wrote:This is my engine bay....needs work...
Thats fine, Mine didnt have an engine in it for three years, Just hang in there,
christer wrote:If I was you, I would swap the orange heater hose for a black one.
   (You should see mine Raven...
 (You should see mine Raven...  I am still working... )
dave-r wrote:Ah!
That is useful. Now I have got something I can draw arrows on and tell you "that bit" when I am trying to direct you to something vital.
That is not too bad in there actually. Just needs some gaskets to stop that oil leak and a bit of tidying up.
Here is mine at the moment. At least until I get some energy back.
 Look's sweet Dave!
 Look's sweet Dave!
dave-r wrote:christer wrote:If I was you, I would swap the orange heater hose for a black one.
Why? It is probably original.
The left bank,(1,3,5,7), appear correct for Hi-Po factory manifolds. The right bank appears like a set off of a b-body or c-body? They are typically much larger than the non-hi-po castings. In other words Wayne has a wrong manifold on one bank. Dont feel bad Wayne, they are being re-popped, but now is an opportunity for a set of polished TTI's or Dougs.christer wrote:RedRaven wrote:This is my engine bay....needs work...
It doesn´t look bad at all if you ask me. If I was you, I would swap the orange heater hose for a black one. Other than that I think it is fairly clean.
Btw; The left (right in the pic´s) exhaust manifold looks higher than the other one. Is it only my eyes, or? (I have always had headders on my car so I hardly know how stock manifolds looks like)
 1 7/8 into 3" collectors into a 2 1/2 inch X-piped Ultr-flo's with Stainless outlets.
drewcrane wrote:the only problem with the stock fan/viscus is that my fear is that it will come apart and trash everything, i plan on getting an electric fan soon!
 I haven't yet mounted any giver for turning on/off do...
