Here's how my car's setup at the moment;
 ENGINE BLOCK :
- '73 340 cubic inch bored .030 over
- forged crankshaft
- forged pistons TRW 2316F
- compression ratio between 10-10.5 : 1
HEADS :
- ported X-heads with 2.05 intake valves cut off a bit
- alu Harlend Sharp roller rockers 1.5 ratio w/ hardened shafts
CAMSHAFT :
- MP solid cam
- 0.528 valve lift
- 284 adv. duration (241@050)
INDUCTION :
- Edelbrock ported performer RPM manifold
- 0.5" carb spacer
- Speed Demon carb 650dp
- home-made air filter underneeth original filter
EXHAUST :
- Hedman headers w/ collectors painted fireproof
- 2.5" dual exhaust system w/ 40series Flowmasters
IGNITION :
- Electr. distributor w/ hardened shaft
- Std orange ignition box MP
- MSD coil
- Taylor wires
OILING :
- Std oil pan w/ home-made baffels
- Std windage tray
- Std oil pump w/ hp spring kit fitted
- Improved oil flow adapter
COOLING :
- Std water pump
- 26" radiator w/ 3 'big' rows
TRANSMISSION :
- 727 TorqueFlite
- Rebuilt by street/strip & little bit track specs.
- B&M deep oil pan
- B&M torque convertor 2400
- B&M Pro ratchet shifter w/ linelock use
AXLE :
- balanced driveshaft
- 8.3/4
- rebuilt 742 Sure-grip diff w/ 3.91 gears
BRAKE SYSTEM :
- Std drums in the back
- Std discs in front w/ 'asbest' pads
- Linelock between front brakes
WHEELS :
- Centerline Telstar 7x15 in front & 8x15 in the back
- Cooper cobra 235/60/15 in front & 275/60/15 in the back
- for strip use 26" BFG Dragradials or MH DOT approved slicks.
STRIP :
- Best ET follows soon
- Best Mph follows soon
This is for so far, till money shows up for new mods.
  (Message edited by 72challenger on June 10, 2003)
