It must have been from your 'old cam' days
So Dave, this new cam you are now using is a better grind with more lobe seperation? Is this why the vacum increase? I bet it's not a smaller bumpstick is it? Care to share the specs?
Old cam was Hughes Hydraulic HE3844BL
Valve lift (w/1.6:1 ratio) 0.571"/0.576"
Duration (@ 0.050” tappet lift) 238/244 degrees.
Lobe Separation Angle 108 I think?
New cam is Hughes Solid HTL3742BS
Valve lift (w1.6:1 ratio) 0.569"/0.579"
Duration (@ 0.050” tappet lift) 237/242 degrees.
Lobe Separation Angle 109
I have also increased the initial advance from 14 to around 18 degrees. I don't know if that has had any effect or not?
It's THE only RTV type of sealer/gasket maker/ adhesive we use in our shop and I should mention it's Oxygen Sensor Safe for both you'rs and Dave's Bosch wide band Oxygen sensors.
