Page 2 of 24
31 Oct 2005 8:36by dave-r
				Getting closer......
I can't thank Matty enough for the work he has put in on this car in his spare time. The car was a lot more rusty and damaged under the filler than either of us thought.
03 Dec 2005 20:02by dave-r
				Car is now painted and back home.
03 Apr 2006 12:35by dave-r
				Well things are not progressing very quickly.
I am having to save a bit of money each month before buying something I need. Also I am finding more problems and more bits that need work as I go.
One minor problem was some contamination that caused a few "holes" or "fish eyes" in the top of one fender. It was not a huge problem but I think i might get that one fender re-painted otherwise it will annoy me every time I see it.
Then I found my painter had not actually removed the front fenders when doing the bodywork. I could have sworn I asked him to and I could have sworn he said he would?
But anyway. Communication breakdown. It means I am now doing bodywork to the tops of the inner fenders and the outer portions of the bulkhead.
The engine is still not together yet either.
First of all I broke a piston ring.
Then I just found one of my new lifters is damaged.
It will all come good in the end. But the end keeps getting further away.
22 Jun 2006 8:34by dave-r
				The engine is almost finished. Just waiting for the polished stainless bolts to arrive so I can bolt it all together correctly.
23 Jun 2006 2:36by JackT
				Dave, I take it that you are using standard-weight connecting rods rather than the heavier MOPAR Six-pack ones since your balancer is symetrical. Am I correct? Nice to see so much progress - I'm hoping for your  speedy return to the strip!
23 Jun 2006 8:03by dave-r
				Actually Jack I am using the six pack rods because that is what was in the engine originally. In fact they are the only major part of the engine still original.
However I did have it internally ballanced which means adding weight to the crank throws.
24 Dec 2006 17:37by dave-r
				Had to do a bit of welding on the inner fender brace and the rear bottom edge of the inner fender to the chassis rail.
It is a funny thing but this area is often not welded by the factory or, as in my case, it is welded on one side of the car and not the other.
25 Dec 2006 15:30by Eddie
				So are you just setting this up for strip use? Do you drive it on the street? I know its fast for sure, does your laws prohibit "loud" exhaust system? Over here in Ind. at least there is a law that states any passenger car can be "taken off the road" if the exhaust is excessive and the arresting officer has all the discretion! Ignorant, huh. What kind of Master you putting on, race single or dual pot, power ect..sorry for all the questions is there a "spec" page? I really like your car and I thought I read where another member ststed you were possibly coming over here for the MoPar Nats? That would be great. Oh I do need to get some stronger eyewear mine eyes are failing me mate, must be old age?
25 Dec 2006 22:03by dave-r
				It is built more for going around corners mate. Not drag racing. It would go a few 10ths faster with a different front end set-up.
It goes as fast as I want it to. I just try to make it as good a driver as possible while still being fast. Any faster times that come along as I mess with it are just icing on the cake.
I doubt I will ever make the Nats over there. I can't justify the money unless my wife came too and that is not going to happen!
04 Jan 2007 21:55by dave-r
				I installed one of these "BeCool" ally radiators a few years ago. It was one of these "bolt-in direct replacement" jobs that cost a fortune. But hey! Being bolt-in saves a lot of hassle right?
Wrong. The damn thing mounted so high the hood would not shut. So I lowered it 2-inches by cutting the brackets welded to the sides.
Now during this rebuild I have dropped the radiator another 1.5-inches because there was a large gap at the bottom of the radiator and the very top of the radiator was behind the radiator frame. And as that is the hottest bit of te radiator i thought it might be better to get it in the airstream.
I still have enough gap at the bottom for oil lines that will go to a combi engine and trans oil cooler mounted out front.
So having done that I thought I may as well paint the front of the thing black so it does not show through the grille.
You can't use normal paint on radiators. You have to use correct automotive radiator paint. This stuff transfers and radiates heat out of the ally.
I have left the engine side plain ally though. Because it looks better that way.
05 Jan 2007 2:17by Eddie
				Dave, is that pic a current one with the Be-cool,( be cool man it fits everything but a MoPar!), radiator in it? If so you did an exemplary job, it looks good!
05 Jan 2007 8:46by dave-r
				airfuelEddie wrote:Dave, is that pic a current one with the Be-cool,( be cool man it fits everything but a MoPar!), radiator in it? If so you did an exemplary job, it looks good!
Took that photo last night.
Here is a photo of the other side of it. Taken a few years ago. You might just see how it is mounted quite high and level with the top of the radiator frame. This is
after dropping it 2-inches already.
05 Jan 2007 17:51by Eddie
				Nice "set-up" Dave. I bet you were pissed that they said bolt-in and it was the opposite.So no fan blade which you really dont need. And nice line lock for the smokeys and heating the rubber. BTW how does it cool compared to the 26" max cooling,(A36).
05 Jan 2007 20:26by dave-r
				It cools better than the stock 26-inch rad for sure despite the core itself not being as wide. With the "tanks" being at the sides instead of the top and bottom you can't really go any wider.
If you check out the spec on the first page you will see I have a high flow water pump as well. The electric fan has a high airflow (bummer about the high current draw that comes with it) and is controled by a Painless relay and thermostat switch screwed into the water pump housing.
Part of my plan this time around is to reduce the amount of time the fan comes on. To do this I need to get more air to the radiator core when the car is moving.
I have noticed that out of all the bugs stuck to the radiator there were very few in the top third of the core and non at all in the top couple of inches.
This is why i just dropped the radiator a bit more.
The other thing I need to do is drop the front licence plate as it is in the way of air entering the space under the bumper.
After that I intend to install plates to stop air spilling out under and around the radiator and force it to go through the core.
lastly I intend to use more initial timing to see if that lowers the engine temp a bit.
Then with a 180 degree thermostat it should maintain a constant temp with the fan coming on only in slow traffic. Hopefully.
12 Jan 2007 16:38by dave-r
				Santa came at last.
21 Feb 2007 17:44by dave-r
				Just did a very quick and very cheap "restoration" on my windscreen wiper motor.
I just did it on my kitchen table. Including time to let the paint dry it took just under three hours.
Not perfect I know but it looks a bit better than before.
22 Feb 2007 18:54by dave-r
				I am not sure if have put my fender tag in the right place or not?
My problem is that there are three holes of equal spacing. I have a feeling the tag was in the first two holes. But it looks better to me in the rear two.
Were they always placed in the exact same position by Chrysler or was it one of these things where different workers put them roughly in the same place but with with some variation??
The rear screw actually goes through the inner fender brace.
23 Feb 2007 15:23by dave-r
				Bulkhead almost finished. Need to clean off overspray etc.
Fitted stainless bolts to the engine where it shows.
23 Feb 2007 16:06by Eddie
				Looks very clean and professional. Are those underdrive pulleys? Do they really help? I have no experience with them I love the way they look and the function makes the engine more efficient?
23 Feb 2007 16:15by dave-r
				Yes that is an underdrive crank pulley.
I wanted the 1-inch belt but could do without the underdrive bit.
Mopar alternators are very poor at low rpms as it is. Underdriving them makes them worse. At idle I can barely keep above 12 volts even though I have increased idle speed.
But I am working on the problem. Less load on the alternator will help.
20 Apr 2007 6:32by 72 Challenger (Hans)
				Dave, nice eh putting back all small things after a paint job. Every single bolt you install makes it looks better and better. Will be a beautifull challenger again when your done and will be a blast to run after all that time and work you've put in! Good to see you've fight an won that weird sickness you had. All fine now?
Anyway, good to see (small) progress every now and then again.
20 Apr 2007 9:28by dave-r
				Nice to hear from you Hans.
I am not quite OK yet but I feel a lot better. Thanks for asking.
At the moment I am trying to organise some friends to come around and help me put the engine/trans back in the car.
After that I will have the room to paint/fit the front suspension and then start on the interior before re-wiring the whole car.
Then I will feel as if I am getting somewhere.
22 Apr 2007 7:58by christer
				dave-r wrote:At the moment I am trying to organise some friends to come around and help me put the engine/trans back in the car.
Do you mean that you will mount it manually? (not using a lift or something?)
dave-r wrote:After that I will have the room to paint/fit the front suspension and then start on the interior before re-wiring the whole car.
Re-wiring the whole car? It sounds like you won´t be un-empoyed in the near future. Isn´t that very time consuming,or? Have you planned to do any mods compared to the original wiring?
22 Apr 2007 9:22by dave-r
				Christer. I am very physically limited at the moment. I am getting better but it will probably be another couple of months before I am even fit for work let alone manhandling a crane with a 440 engine hanging from it.
I could prodable do it but the effort would have me in bed for a week with blinding headaches.
I did build a simple wooden trolley to carry the engine and transmission under the car but that was before I became ill.
Yes I am going to completely re-wire the car with the Painless kit as the existing wiring is not great in many places. Yes it is going to be modified to reduce the load on the alternator as much as possible and also maintain a high voltage in the wiring harness. Currently the voltage in most of the harness is only 11 volts when under load. In some places it is less than that.
22 Apr 2007 9:29by dave-r
				I got a few things for christmas.
These were the main bits in my present.
22 Apr 2007 9:57by christer
				dave-r wrote:Christer. I am very physically limited at the moment. I am getting better but it will probably be another couple of months before I am even fit for work let alone manhandling a crane with a 440 engine hanging from it.
I am sorry to hear that the illness still makes your life a bit difficult. The main thing is that you are getting better all of the time.
dave-r wrote:I did build a simple wooden trolley to carry the engine and transmission under the car but that was before I became ill.
I suppose that you are going to use some kind of winch then.
dave-r wrote:Yes I am going to completely re-wire the car with the Painless kit as the existing wiring is not great in many places. Yes it is going to be modified to reduce the load on the alternator as much as possible and also maintain a high voltage in the wiring harness. Currently the voltage in most of the harness is only 11 volts when under load. In some places it is less than that.
I hope that it will be as painless as the name implies. I think you will make it quite easy considering your electrical skill. I am quite sure that you will let us know about your progress, right? That will be intresting reading.
 I am not keen to start any similar project myself though
22 Apr 2007 10:00by christer
				dave-r wrote:I got a few things for christmas.
You got a very generous Santa over there, that´s for sure.
  I think I will send him an air ticket so that he can come over to my place.
22 Apr 2007 12:07by dave-r
				Christer. I need a crane to lift the engine off the stand and lower it onto the K-frame on the trolley.
Then I have to bolt the flex plate on, fit the torque converter, and bolt the engine and trans together while at the same time fitting the starter motor behind the exhaust pipes.
Then I have to fit the bumper brackets. I couldn't do that before because the bolts for the brackets were holding the engine to the engine stand!
Once the brackets are in place we can lift the front of the car up with the crane and some chains and slide the engine/trans under. Then lower the car onto the k-frame and bolt in place.
Then a lightweight jack will lift the end of the trans up so we can bolt the trans crossmember into place.
All very simple. But much easier (and safer) if a few friends are helping out.
22 Apr 2007 14:10by christer
				It seems to be a handy way of doing it
  ( to lower the body on the engine-trans-Kmember-setup). I will try it the next time.
22 Apr 2007 14:38by Eddie
				Thats the way the factory did it. It's also the ONLY way in my opinion! That digi6 looks nice Dave. With only 11 volts in the harness, then it's time for a new one. Painless appears to be an easy replacement although I have never used them. They used to only make products for Chevys and Fords, guess the MoPar presence can't be denied.
