Adrian Worman wrote:All ragtops are cool anyway but knowing you're fondness for track ability I expect it to be something interesting
No way!!
this is a Convertible (ie a chick magnet bolted on rubber & cardboard chassis. Besides, old american cars only seem to attract bald guys in their mid forties, but I digress).
So, it won't have a huge swaybar, tubular suspension and radiator support, or any of the go-fast stuff I like so much.
What I want for this car :
I want it to be easy to drive (no separate switches for the fuel pump, fan, water pump, etc).
No noise.
Anywhere there can be water will be made waterproof (especially the convertible top drip rail and the insides of the quarter panels).
(Almost) stock-cammed engine, idles like a charm, doesn't wake the neighbours (at least, not more than any of the ****ing diesel-engined cars that seem to be anywhere these days)
Suspension will consist in :
A stock K-frame, rewelded.
Stock upper and lower control arms, possibly with LCA plates welded on. Not sure about this one.
A complete suspension kit including polyurethane for all bushings with a rotating motion (ie LCA bushings), rubber on all others. Haven't spent too many nights on the FirmFeel website, but it will happen...
I'll add a sway-bar in the rear, an OEM 1970 swaybar I removed from my hardtop.
The chassis gets the US Car Tool frame connectors, and I'll repair the rear torque boxes (one has been cosmetically damaged by an ill-placed jack, I suppose).
A complete rust-proofing inside the framerails will be done (right now, theres absolutely no rust there, I checked!)
Body-wise, the cowl will bze replaced, and the trunk floor and extensions too. The other rust spots will be dealt with the old-fashioned way, my body man seems confident.
Interior-wise, the blue interior (damaged beyond repair, most everything was reupholstered in leather 20 years ago, so the new interior will be black. I'll have to come up with a solution to repair and dye/pint/recover in black vinyl the original rear panels, which are not reproduced.
Dash pad is new, as are the door panels. Still have to get kick panels and a 1970 console, some dash trim, etc.
Not sure yet about the seats, either all-vinyl new covers, or have them done in black leather following the original pattern.
Black convertible top (I've had it for 6 or 7 years now) with a glass rear window.
Outside color is not decided yet, but it will be blue, right now I have a modern chrysler color which looks OK.
I'd like to add a bit of depth with small bronze metal flakes in the clear, and a bumblebee stripe (Bronze?Yellow?White? not decided yet). Tests are underway.
I'd like it to look 100% stock under the hood, but I'll make one concession to modern electronics, with an electronic ignition (just like it was when new, with the ECU bracket on the firewall). Ideally, the 440-6pack will be replaced by a 383-4bbl (but there's still time for this, the 440 will be used for some time).
Not very 70-ish, but I'd love to have a thermoquad (small primaries, easy to setup, huge secondaries).
Not everything is stock-looking, I'll use the QA1 adjustable shocks I took off of my hardtop, 1973 front spindles and bearings, OEM disc brakes (11.75 rotors), rear drums, with Rallye wheels and stock-sized tires (or close to stock-size).
Might even spring for a set of body-colored steelies with dog dishes and a set of Polyglas tires (although the price will probably deter me from that option).
I was thinking about sending my instruent cluster to the USA to have it rebuilt, but the instruments look brand new, so that won't be mecessary.
Only the bezel needs some work.
