JackT wrote:I agree about the safety factor. I want to take it down the strip at least once for an ET on it after the new short block is in it. Maybe the bell housing should wait until after that happens. The block in the car isn't the original one, however it is an over-the counter replacement with a June 15, 1968 casting date.
Dont know if I understand this correctly Jack T. but could you possibly use the Keisler? It's SFI and able to fit the both types of different diameter clutch assemblies,,has aluminum/titanium alloy much stronger than stock but not much heavier, maybe a pound or two, looks 'stock' unlike the sheetmetal types. Hope this helps, Eddie
