ESP
Postby NCEMT » 06 Nov 2008 3:19
Is there an absolute way to rid this? I know the trick to turn off,on- then hold off for @ 6 secs. However, now that I have supercharged mine, I have found that it is still trying to control traction. Aggrevating as hell. Any help would be greatly appreciated.
NCEMT
Postby Eddie » 06 Nov 2008 15:41
Do you know anyone that has a DRB scan tool? If so they should be able to 'hook you up' no pun intended. The scan tool should have the ability to 'turn' it on/off. Have you checked the fuse box to see if there is a fuse for the Electronic traction control?(This may cause the Check Engine Light to stay on until it's cleared with the DRB)) This is speculation. I have NO experience with the 08/09 Challenger.
Postby Eddie » 07 Nov 2008 21:45
The switch is inside the cockpit of 2008 models. It disables the traction control. I dont know if it's the same on 2009 models but I would assume it is. I recieved this info from the Tech guys at the dealership. No need for a DRB scan tool.
