http://www.youtube.com/watch?v=91dmTS-UvDc
http://www.youtube.com/watch?v=4-w-tGU0Nks
Cheers
. We have adjustable tubular uca's on heim joints, Alloy adjustable struts also on heim joints (at the "K" end). The only poly bush is in the lca. Figure it needs a good set up. We got +5 castor, 0 camber and 1/32 toe in @ +1 ride height but the hub arms where heated to bend them up when I had a different set up. Car is stable at speed but cross winds will effect it. Best MPH is 142.5 and @ 3830lb race weight approximates to a 850ish HP motor. Thanks for putting them on the MMA site Dave wrote:Dave r: No Rubber bushes here. We have adjustable tubular uca's on heim joints, Alloy adjustable struts also on heim joints (at the "K" end). The only poly bush is in the lca.
