check out this clip of my 6 pack ideling,sweet
http://s165.photobucket.com/albums/u68/ ... ndclip.flv
also added some new photos.
christer wrote:It is a pity that there is no radio station who plays this kind of music.![]()
It both runs and looks great!It can´t get much better than that, right?
rtse4406pack wrote:christer wrote:It is a pity that there is no radio station who plays this kind of music.![]()
well like you say christer,maximum joy is a hemi but the 440 6 pack sure is close to maximum joy!
Sometimes I dream about fitting them on my 383". I guess it is just a matter of money. Six-pack equipped 383"-s are quite rare, are not they?
rtse4406pack wrote:"I have learned that all three carbs have an idle circuit, right?" christer i am not sure about this,i heard everything pretty much runs on the middle carb and the other two are mechanical?
rtse4406pack wrote:"383 with 6 pack",i never heard of this package,was there an original set up like that?
rtse4406pack wrote:all i can say is that the factory 6 pack set up does take awhile to warm up after start up,about 3 to 5 minutes. but when it gets warmed up it pretty much stays there the way you here it on my video. it does not change even if i put it in nuetral at a red light.
to start the motor it is a bit tough too and does take a few turns,but i am getting used to it and getting better each time by giving the motor much more gas as i turn the key. i have run into many hemi and 6 pack guys and they all say the same thing about start up. if its the stock set up (dual points with original distributor) it is a bit of a bitch in start up.
but let me tell you,when i start it at a cruise in, i get about 30 to 40 guys around the car just stareing at the shaker bubble as it just shakes perfectly at 900 rpm's.
forgot to mention that after the car is warmed up it does start a lot quiker. usually 1 to 2 turns.
Mothers SixPack was ahead of it's time!!
Yep AF ratio not idle rpm.dave-r wrote:My mid 70s Jensen Interceptor six pack (jensen used them way after Chrysler stopped) does not have any idle circuits in the outboard carbs.
Also I had mine converted to pure mechanical operation with accelerator pumps on the outboards.
