Yes, I have not decided how to rake it.
I'd like to keep the rear end concealed within the body so it is covered by that rear panel, but I'd like to keep the rear of the car raised at least 2 or 3 inches over the front. Now that I have the exact dimensions of the components modeled, I plan on moving components around quite a bit to determine where I want them.
I am undecided as to what to do for a grille. The grille I modeled is the only one that seems to look right, but it is very small and it would cause big problems for putting in a radiator.
As far as parts for it, itll be mopar drivetrain, and I'm going to make as much as I can. Dashboard, body, frame, everything will be built. Seats I might construct, and I'll probably buy a set of gauges in the end. I dont plan on buying anything from a junkyard, I want to build this as my own style of rod and I'd rather make my own pieces before I put on original 30's stuff.
What did i get myself into?
