Hello,
I will be upgrading the 383 in my challenger to a slightly modified street 440 (450-475 hp), but the original radiator core support is for a 22" radiator. I know I need to increase the cooling capacity (car has AT, but no A/C), but I'm wondering if I can bolt the 26" radiator using the smaller support? Summitt carries a set of brackets that can be drilled for installing a larger radiator in a car that has a 22" wide opening. I will be using a fan shroud with a stock type viscous fan. I do not want to replace the radiator support with the larger 26" unit, even though they make reproductions for this. Are there any other issues to consider (clearance,t-stat selection, fan selection) ?
I'd like to keep the modifications as close to stock as possible.
Thanks,
Chris
