				340 4Barrel Upper Rad Hose
07 Aug 2008 22:01by DanaProsky
				I am trying to get a correct upper rad hose for my 71 340 4BBL. Is the hose for a 70 340 6 pack the same as my car. Year One lists one for the 340 6 pack motor, but not the 4 barrel motor, I'm thinking its the same hose, but I'm not sure.
08 Aug 2008 8:17by dave-r
				The T/A hose is a different part number.
I would guess if you do not have air conditioning it would still fit as long as the radiator inlet is on the drivers side. My worry would be that a air con pump might be in the way?
08 Aug 2008 14:33by DanaProsky
				Thanks Dave,  I do not have air conditioning, the Year One catalog is very vague as far as which hose number fits which engine, etc. As a matter of fact, the online catalog shows more hoses than the paper catalog. I am trying to get a "correct" hose for my car. I called their "tech line" but was on hold for 45 minutes, so I gave up. The 340 6 pak and 4 bbl engines are similar, but the intake manifolds being different could mean 2 different upper hoses.
08 Aug 2008 17:28by dave-r
				The water necks (and their position) are the same. But the hose probably has to bend forward a bit to avoid the front carb.
I think if you dont have air con it would fit. But it would not be the "correct" hose.
Actually I think it is the shaker hood that makes the biggest difference.
PN 1881806 is the top hose you need.
PN 3462118 is for shaker hoods and the T/A I think?
08 Aug 2008 17:41by DanaProsky
				Thanks again Dave,  When I say "correct" hose, I mean a hose with the pentastar logo and part number, etc. It may not even be available at this time. I just got my correct heater hoses with logos, etc, I am trying to do the car right.
08 Aug 2008 17:52by dave-r
				Here are the top hose part numbers in the 70-71 parts manual.
All the LA blocks have the same water pump and radiators. The difference being fresh air induction (shaker and T/A) and max cool radiator.
09 Aug 2008 2:17by DanaProsky
				Looks like number 3462118 is the one I need for my Shaker 340, I wonder what the chance of finding a NOS hose is.  Thanks Dave.
09 Aug 2008 9:37by dave-r
				You have a shaker! I think that is the one Year One  list as for the Six pack. So that one is the one you need.
09 Aug 2008 14:14by DanaProsky
				Year One lists a SR213 for 70-71 340 AARs & T/As and the factory number stamped on the hose is 3462193. If I am reading things right, that number is the one for a 70, and 71 has a different number, 3462118. Year One doesnt even mention a difference between a Shaker car and a non-Shaker car. I would assume the fit on some of their hoses is not the best.
09 Aug 2008 15:34by dave-r
				The Year One item will fit with your Shaker. It fitted the 1970 model so it will fit yours I am sure.
20 Aug 2008 18:37by Gordon
				I have a 340 in my '70.  I got what Year One listed as the "correct" upper hose for my car, and it fit fine.  Then I added a repo Shaker set-up.  The upper hose still fits fine and there are no interference issues.  Since the car isn't 100% OE anymore, it doesn't bother me in the least that the small number printed on the hose isn't correct anymore.....
